mccldwll Posted March 26, 2008 Share Posted March 26, 2008 Just had a 75K service (glorified oil change, plus cabin filter) done by a very good indy shop. Very good relationship. Today discovered that power tailgate does not work, either by remote, interior button or tailgate button to lower. The motor which completes closure after you lower it still works. What might be going on? Is there one fuse for that motor? Anything else on that circuit? Where to be found? Other possibilities? Thanks. Quote Link to comment Share on other sites More sharing options...
thdoan Posted April 11, 2008 Share Posted April 11, 2008 Just had a 75K service (glorified oil change, plus cabin filter) done by a very good indy shop. Very good relationship. Today discovered that power tailgate does not work, either by remote, interior button or tailgate button to lower. The motor which completes closure after you lower it still works. What might be going on? Is there one fuse for that motor? Anything else on that circuit? Where to be found? Other possibilities?Thanks. Have you checked the on/off button inside the glove box compartment, on the left side. That button is used to disable the power read hatch if necessary. Hope that it helps, Quote Link to comment Share on other sites More sharing options...
KBRX330 Posted April 12, 2008 Share Posted April 12, 2008 Check the gas strut that holds the door up. Probably weak and needs replacing. Quote Link to comment Share on other sites More sharing options...
mccldwll Posted April 13, 2008 Author Share Posted April 13, 2008 Just had a 75K service (glorified oil change, plus cabin filter) done by a very good indy shop. Very good relationship. Today discovered that power tailgate does not work, either by remote, interior button or tailgate button to lower. The motor which completes closure after you lower it still works. What might be going on? Is there one fuse for that motor? Anything else on that circuit? Where to be found? Other possibilities?Thanks. Have you checked the on/off button inside the glove box compartment, on the left side. That button is used to disable the power read hatch if necessary. Hope that it helps, Right after I posted I remembered that. Problem solved. Sorry for not posting back. Quote Link to comment Share on other sites More sharing options...
prcp37tlexus Posted September 23, 2008 Share Posted September 23, 2008 Just had a 75K service (glorified oil change, plus cabin filter) done by a very good indy shop. Very good relationship. Today discovered that power tailgate does not work, either by remote, interior button or tailgate button to lower. The motor which completes closure after you lower it still works. What might be going on? Is there one fuse for that motor? Anything else on that circuit? Where to be found? Other possibilities?Thanks. Hi - thanks for the help. I had xm sat radio installed yesterday and all of a sudden tailgate stopped working. Toggled switch at left side of glove box and now everything is fine!! Quote Link to comment Share on other sites More sharing options...
asif01 Posted December 7, 2013 Share Posted December 7, 2013 hi can anyone tell that if the switch in the glove box in pressed down or pushed down then the back door will open auto or manually? Quote Link to comment Share on other sites More sharing options...
