1994 Lexus Es300, 135,000 Tune Up
I have a 1994 ES300 with 135k miles
1. What should I get done for 135k miles?
2. My car jerks/jumps up then down when shifted from parking to reverse, what is the problem?
Last major service was done at 118k miles in 2006, I called, each dealer quote me differently. For $450 at Fremont, CA. This is what I'm getting.
Replace engine oil and filter
Replace EFI air intake filter
Replace transmission fluid
Replace differential fluid
Inspect engine coolant
Inspect battery electrolyte
Inspect power steering fluid
Inspect and adjust handbrake
Balance front tires
Inspect tires and set pressures
Inspect brake pads and rotors
Rotate tires
Inspect undercarriage
Inspect alternator drive belt
Lubricate chassis and hinges
Inspect wiper blades
Inspect and fill washer fluid
Inspect all lights
Add fuel treatment to clean out the fuel injectors
Complimentary car wash
What are some of the things that's actually needed? thanks. =]
I have a 94 also, you should check your motor mounts or transmission mounts with that park to reverse issue jerking. Also check your valve cover gaskets for seepage or leaks. The dogbone mount is real easy to replace. You can buy a dog bone mount at pep boys for $ 26.00.
Balance front tires
Rotate tires
Inspect all lights
Seems a bit high considering many of the items are 'inspect' (AKA look at). :blink: Most of those you can easily do yourself.
Inspect wiper blades, PS & washer fluid? :rolleyes:
And why do they only suggest to balance the front tires only & after do a tire rotation? :huh:
Also, isn't the diif fluid just tranny fluid anyway? When you do a drain & fill on your tranny & not a seperate fluid? I could be wrong however because of the model year.
When was the last time you had a complete tune up on the car? Tell them for that price, you will bring all the necessary parts to them to install. ;)
:cheers:
Lexusfreak- You can't get mad at the guy on the price since that is 100% typical Lexus prices. Lexus LOVES the good-old inspect deal...It is free money!
But he is paying normal prices; $450 for about $100 worth of material..but he gets a free hack wash job too!
