eXo Posted December 3, 2003 Posted December 3, 2003 Hi Guys, I just bought a 2nd hand autometer air/fuel ratio guage. It came out of a GTi-R pulsar and I'll be throwing it into my 1jz '94 Soarer. Has anyone installed these before and if so, where is the air/fuel wire that goes into the ECU ? The closest I've seen is to find the sensor and tap in there. Has anyone installed a similar guage of any brand before. If so, where does the 3rd wire go ? The autometer site is pathetic for tech instructions. <_< :whistles:
SKperformance Posted December 3, 2003 Posted December 3, 2003 what is the third wire? you should have +12 vdc - ground + backlight wire to the sensor tap which one? i tapped my afr to the ecu wiring it depends on which sensor you want to see ,before or after the cat
