Check Engine Light Came On Ls400 1999 Model
monty_mm
Hi guys, i've been searching the forum for a while to see whether i could solve my problem.
My problem is that the check engine light came on for some time now. i dont know what the problem is and cannot tell since everything seems to be normal and the car runs perfect.
i didnt send it to any repair shop yet to read the codes, i was wondering if anybody could tell me what could be the possible cause(s) since there seems to be no problem with the car.
I read somewhere that it could be the fuel cap, i tightened it, removed by batteries to reset the light, and it came on again after a while.
everytime i disconnect my batteries, the light would go off for a while and after driving for a while (maybe 15-20 minutes), the light will come on again.
anybody any ideas??? would be greatly appreciated.
regards,
monty
Could be anything...
Bad Oxygen sensors is a common thing that you possibly wouldn;t notice in the running of your vehicles.
I am from canada, so it doesn;t apply, but in the US, I m pretty sure that 'autozone' will check and tell you what your codes are, free of charge, so I would recommend that. Until you know your codes, you will not know what the problem is for sure.
thanks aarman4, at least now i can have a look at least at the wiring to the oxygen sensors to see if everything is ok before taking it anywhere. thanks again. will come back to the forum once i get any codes!
Best of luck! The wiring is probably fine though, those sensors have a shorter lifespan than they should.
