Niko Posted February 24, 2008 Share Posted February 24, 2008 The speedo and tach needles are burnt out on my 95 es300. I took my cluster completely apart and can't figure out how to take the needles off whatsoever. Can someone help? Also, I was wondering if anyone knows if there is a way to fix the needles instead of replacing them. Thank you. Quote Link to comment Share on other sites More sharing options...
cbenton Posted February 25, 2008 Share Posted February 25, 2008 I have the same problem. If you find out, please let me know. THX. Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 25, 2008 Share Posted February 25, 2008 I have the same problem. If you find out, please let me know. THX. This topic has been covered extensively, Use the search feature at the top of these forums and have a good time reading all of the posts. BTW, Welcome to the club Or contact www.lextech.org Let Brian know that I sent you. Quote Link to comment Share on other sites More sharing options...
busoptr Posted February 25, 2008 Share Posted February 25, 2008 The speedo and tach needles are burnt out on my 95 es300. I took my cluster completely apart and can't figure out how to take the needles off whatsoever. Can someone help? Also, I was wondering if anyone knows if there is a way to fix the needles instead of replacing them. Thank you. The great LEXUCAN posted a extensive diy on the needles. Someone said you just pull the needles out but Im not sure, I tired that at the junkyad and the needles broke. It was from a LS. Maybe different style. I live 15 minutes from the junk yard and they got some es300's there and also camrys which has the same engine and mechanical parts as the es300. Quote Link to comment Share on other sites More sharing options...
Niko Posted February 26, 2008 Author Share Posted February 26, 2008 Thanks guys. I read up on it. I'm gonna try to repair them myself. Quote Link to comment Share on other sites More sharing options...
Lexucan Posted February 26, 2008 Share Posted February 26, 2008 Someone said you just pull the needles out but Im not sure, I tired that at the junkyad and the needles broke. It was from a LS. Maybe different style. Junkyad? Do I detect a New England accent? LOL Yes, the needles just pull off the gauges and no, they are not the same as the LS needles. Keep in mind that they are made of plastic with a string of LEDs behind the opaque lens so they are relatively fragile. You need to be careful when removing them from the gauge face and only grasp them gently around the point at which they attach to the gauge and pull straight out, not at an angle. I found that two came off fairly easily while the other two were more stubborn and needed extra effort. Quote Link to comment Share on other sites More sharing options...
