Chaning Sparkplugs For My 97 Ls400
DanLee
I am going to change the sparkplugs on my 97 LS400. I heard that it's a Distributorless ignition system. Can anyone confirm? no wire to replace. Do you still use dielectric grease even there's no wire? Still thinking whether to get iridium or platinum plugs. I changed sparkplugs for other cars before. Any advice/precaution specific to this car? Thanks.
Welcome to LOC Dan :)
Here is the info I was able to find for your 97 LS...
http://www.ngksparkplugs.com/part_finder/c...?engineid=26667
:cheers:
There are wires to replace but check the resistance on them first. I'd go with OEM wires (if you need to replace them) because they fit like a glove--each wire is cut to the exact length. I've always run iridium plugs, and I've got no complaints as far as mileage or performance is concerned.
Also, a 10" extension for your ratchet with a spark plug socket makes it quiet easy to fish the plugs out. ;)
