Power Pack Posted February 8, 2008 Share Posted February 8, 2008 1998 GS400 - Passenger side HID Headlight and Parking light are fogged with apparent condensation on the inside. I'm somewhat of a perfectionist and it really annoys me as well as the thought of reduced night vision. One would think that you pop the outer cover, either wipe it out and reseal it, or replace the cover. Not! Dealer indicates that it's all one big mother unit and all but bulb must be replaced. Quote of $850+ including labor. This is only for the right side! Any comments, suggestions, or do I either live with it or bite the bullet. Thanks! Bob S. Eugene, Oregon Quote Link to comment Share on other sites More sharing options...
domsgs430 Posted February 9, 2008 Share Posted February 9, 2008 1998 GS400 - Passenger side HID Headlight and Parking light are fogged with apparent condensation on the inside. I'm somewhat of a perfectionist and it really annoys me as well as the thought of reduced night vision.One would think that you pop the outer cover, either wipe it out and reseal it, or replace the cover. Not! Dealer indicates that it's all one big mother unit and all but bulb must be replaced. Quote of $850+ including labor. This is only for the right side! Any comments, suggestions, or do I either live with it or bite the bullet. Thanks! Bob S. Eugene, Oregon Try using a blow dryer on it and see if it evaperates the water on the inside then figure out a way to seal the leak so it doesn't happen again Quote Link to comment Share on other sites More sharing options...
Power Pack Posted February 9, 2008 Author Share Posted February 9, 2008 1998 GS400 - Passenger side HID Headlight and Parking light are fogged with apparent condensation on the inside. I'm somewhat of a perfectionist and it really annoys me as well as the thought of reduced night vision.One would think that you pop the outer cover, either wipe it out and reseal it, or replace the cover. Not! Dealer indicates that it's all one big mother unit and all but bulb must be replaced. Quote of $850+ including labor. This is only for the right side! Any comments, suggestions, or do I either live with it or bite the bullet. Thanks! Bob S. Eugene, Oregon Try using a blow dryer on it and see if it evaperates the water on the inside then figure out a way to seal the leak so it doesn't happen again Thanks! That thought crossed my mind but was concerned that lens might crack. Think I'll let my wife do it. She handles those contraptions better then I do. Quote Link to comment Share on other sites More sharing options...
GS400-79 Posted June 8, 2008 Share Posted June 8, 2008 How did you work out. I have the same problem and would like to fix it up. Quote Link to comment Share on other sites More sharing options...
sakataj Posted June 11, 2008 Share Posted June 11, 2008 so did you get your sealed? my 430's right headlight has condensation in it also! i will welcome myself back to the forum as im woo hooooooooo im finally unsuspended! hahaha! brian Quote Link to comment Share on other sites More sharing options...
