06gs430 Posted January 29, 2008 Share Posted January 29, 2008 my left headlight randomly turns off. i dont know if its happened because the right headlight more than compensates for it. the only way i notice is if i pull into a 7/11 or something and i notice in the reflection of the windows that only one of my headlights is on. when i turn the switch to off and back to on, both lights are on. Quote Link to comment Share on other sites More sharing options...
The G Man Posted January 29, 2008 Share Posted January 29, 2008 The left headlight should never turn off if the right one is on. You have a problem there, bring it back to the dealer to get it fix. Quote Link to comment Share on other sites More sharing options...
FRISK Posted February 24, 2008 Share Posted February 24, 2008 my left headlight randomly turns off. i dont know if its happened because the right headlight more than compensates for it. the only way i notice is if i pull into a 7/11 or something and i notice in the reflection of the windows that only one of my headlights is on.when i turn the switch to off and back to on, both lights are on. i have that problem too.i had it 4 a yr now...they replaced the left lamp then the right does it.i just replace that one 3days ago now the day time running lights dont work when headlights on no more...but i called the lemon law so i have a case they said i sent them the workorders and bill of sale.... Quote Link to comment Share on other sites More sharing options...
Step Hen Posted March 3, 2008 Share Posted March 3, 2008 i have that problem too.i had it 4 a yr now...they replaced the left lamp then the right does it.i just replace that one 3days ago now the day time running lights dont work when headlights on no more...but i called the lemon law so i have a case they said i sent them the workorders and bill of sale.... Sorry but doubt that you will get a lemon law case because of a headlight fault. Usually the recurring problem has to be more serious and endanger the owner through its continued usage (though you could argue headlights are important!). Good luck. It sounds more like a harness problem or a wiring problem. Have you replaced the fuse with a higher amp one by any chance? Quote Link to comment Share on other sites More sharing options...
Step Hen Posted March 3, 2008 Share Posted March 3, 2008 my left headlight randomly turns off. i dont know if its happened because the right headlight more than compensates for it. the only way i notice is if i pull into a 7/11 or something and i notice in the reflection of the windows that only one of my headlights is on.when i turn the switch to off and back to on, both lights are on. Looks like you're still under warranty. Take it in and have them take a look at it. Don't think it's something that you can fix yourself as a part sounds faulty (assembly, harness, wiring, etc). Quote Link to comment Share on other sites More sharing options...
