lexus999 Posted January 28, 2008 Posted January 28, 2008 Hello fellow members, I would appreciate it if someone could give me the instruction on how to open the center console and get to the lighter wiring. Thanks Lexus SC400 '95
GaDawg Posted January 31, 2008 Posted January 31, 2008 Hello fellow members,I would appreciate it if someone could give me the instruction on how to open the center console and get to the lighter wiring. Thanks Lexus SC400 '95 1. Pull out cup holder. 2. Remove screws holding down the rear portion of the console. 3. Assuming you have an AT, slide the trim on the stalk of the shifter down to expose two, rear-facing screws....remove screws. 4. Remove ashtray 5. Pull up panel around shifter and unplug wiring harnesses. 6. Remove screws at base of center console behind the ashtray assembly. 7. Pull out and down towards the shifter and the whole trim comes off. 8. You're good to go. I'm pretty sure I covered all the steps...if I missed one, it'll be obvious what it is and what you'll need to do. Cheers.
xxdonvitorulesxx Posted September 6, 2008 Posted September 6, 2008 I'm having a problem with a bad lighter socket which means i can't use cell phone car chargers and also radio transmitters for iPod's. Could i get to where i could pull out the old socket and put in a new one by following these steps to take apart the console?
SeanGrac Posted September 8, 2008 Posted September 8, 2008 I'm having a problem with a bad lighter socket which means i can't use cell phone car chargers and also radio transmitters for iPod's. Could i get to where i could pull out the old socket and put in a new one by following these steps to take apart the console? yes
