Julia Posted January 26, 2008 Share Posted January 26, 2008 I have a 1998 ES300 with 151K miles. Recently, because of leaks in three different areas, I spent $2,500 to replace all seals, gaskets, camshaft valves, all belts and water pump. The car runs very well (and quiet too), although I feel like the pick up is not as good as it used to be. My mechanic (an independent mechanic) asked me when was the last time I had the fuel filter replaced. He said he always recommend his client to replace the fuel filter every 60K miles. I checked my old record from the dealer, but it did not show any replacement of fuel filter. Anyone has any advise? - Julia Quote Link to comment Share on other sites More sharing options...
camlex Posted January 26, 2008 Share Posted January 26, 2008 people says you don't needs to. but I do replace when i change my Timing belts (90,000) Hope that helps. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted January 26, 2008 Share Posted January 26, 2008 I'd do mine every 60k miles too. :) Is yours in tank or under the hood? Quote Link to comment Share on other sites More sharing options...
Julia Posted January 26, 2008 Author Share Posted January 26, 2008 I am not sure its exact location, but was told it's next to the fuel injection. I was also told it's about a two-hour job. How much did it cost yours done? Or did you do it yourself? Quote Link to comment Share on other sites More sharing options...
mburnickas Posted January 26, 2008 Share Posted January 26, 2008 I am not sure its exact location, but was told it's next to the fuel injection. I was also told it's about a two-hour job. How much did it cost yours done? Or did you do it yourself? On a 98, it is about a 30 minute job... Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted January 28, 2008 Share Posted January 28, 2008 I had it done on my 2001 ES for dirt cheap if I remember.....my 2005 however is in the tank AFAIK & never needs replacement. Quote Link to comment Share on other sites More sharing options...
