candanedo Posted January 22, 2008 Share Posted January 22, 2008 Hi I have a 2000 Lexus GS400. We have just noticed this past week that when you are slowing down and turning sharp right there is a pop noise. It doesn't happen when you are turning left only to the right. It is not every time you turn right, just like if I was to turn into a parking spot to the right and hit my brakes there is a pop noise. Has anyone had that problem before and if so what was the problem. Thanks Quote Link to comment Share on other sites More sharing options...
modifyit15 Posted February 4, 2008 Share Posted February 4, 2008 yep I had that problem And it wasnt tillit got really bad then I found out it was the lower ball joint changed it today and now its fine, its about 90 bucks at lexus, and takws about 45 mins to change but make sure you have a puller and a couple jacks or a jack stand and a jack Quote Link to comment Share on other sites More sharing options...
99blkgs Posted February 17, 2008 Share Posted February 17, 2008 my car makes the same noise in the front end (99 s300) and i put it up today and moved the wheels by hand left to right and top to bottom and it is extremely tight with no play in it, i am lost any suggestions anyone??? Quote Link to comment Share on other sites More sharing options...
A_GS300 Posted February 18, 2008 Share Posted February 18, 2008 Hi I have a 2000 Lexus GS400. We have just noticed this past week that when you are slowing down and turning sharp right there is a pop noise. It doesn't happen when you are turning left only to the right. It is not every time you turn right, just like if I was to turn into a parking spot to the right and hit my brakes there is a pop noise. Has anyone had that problem before and if so what was the problem. Thanks Sounds like ur brakes dude. Could be your pad fittings coming loose, do a search on the forum for "brake noises" or "brake fitting kit". Hope this helps. Quote Link to comment Share on other sites More sharing options...
