moe&michelle Posted January 7, 2008 Posted January 7, 2008 I HAVE AN SC 400 1995, AND WOULD LIKE TO KNOW, SINCE I HAVE 18'' RIMS, MY REAR TIRES WEAR OUT ON THE INSIDE, DOES ANY ONE KNOW IF ITS THE TOE IN OR OUT, OR DO I NEED TO GET A PART?
JIBBBY Posted January 8, 2008 Posted January 8, 2008 The rear camber typically wears out on the rear suspension...Try a wheel allignment to see if the rears can be alligned properly... If not you will need to change out the bushings and what not...
JIBBBY Posted January 11, 2008 Posted January 11, 2008 Allign it...If it doesn't allign all the way you need parts....
