How Do You Reset The Oil Maintenance Required Indicator?
I want to do my own oil changes, but can't figure out how to reset the oil maintenance required indicator. Everything I've read says to old the odometer reset button, but there isn't one on the 2007 IS (at least not one I can find). Does anyone know how to re-set this?
nChanging the engine oil (U.S.A. only)
To reset the oil change system, follow the procedure below:
1. Turn the engine switch OFF.
2. While pressing the trip meter reset knob (→P. 100), set the engine switch to the
IG-ON mode. Continue to press and hold the knob until the trip meter displays
000000.
http://us.lexusownersclub.com/forums/index...ost&id=3751
http://us.lexusownersclub.com/forums/index...ost&id=3761
