Gs300Luver Posted November 30, 2007 Share Posted November 30, 2007 Soooo.. I check my transition oil today (cold).. and its WAYYYYYYY past were it suposed to be.. I mean really full.. I been drinving like this for a while now.. I am so scared.. What does this mean?? Will it be all messed up now? Should I take it to someone to fix it?? should I take some out.. what do I do.. I bought the car last week.. do you think the guy did that because it has transition problems? Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 30, 2007 Share Posted November 30, 2007 Soooo.. I check my transition oil today (cold).. and its WAYYYYYYY past were it suposed to be.. I mean really full.. I been drinving like this for a while now.. I am so scared.. What does this mean?? Will it be all messed up now? Should I take it to someone to fix it?? should I take some out.. what do I do.. I bought the car last week.. do you think the guy did that because it has transition problems? First, Drain and fill to spec. I am almost certain that the fill is 2 qts. ( that is what my fill is on my 1998 gs300 ). DOUBLE CHECK YOUR OWNERS MANUAL. Quote Link to comment Share on other sites More sharing options...
SRK Posted November 30, 2007 Share Posted November 30, 2007 Did you check the level with engine idling in neutral, car on level ground, or did you check it with the engine off? It must be checked with the engine running, otherwise the level will appear quite high. Quote Link to comment Share on other sites More sharing options...
Gs300Luver Posted December 1, 2007 Author Share Posted December 1, 2007 so I guess everything is ok.. I took it to the guy down the street and he said that it needs to be checked when the car is running.. so everything is fine.. Quote Link to comment Share on other sites More sharing options...
SRK Posted December 1, 2007 Share Posted December 1, 2007 so I guess everything is ok.. I took it to the guy down the street and he said that it needs to be checked when the car is running.. so everything is fine.. You're welcome...... Quote Link to comment Share on other sites More sharing options...
