shaun786 Posted November 30, 2007 Share Posted November 30, 2007 I have a 1996 LS400 Can somebody tell me how to replace a fuse ... Because my cig lighter, climate control, and clock stopped working... Also, where can I get a fuse from? Quote Link to comment Share on other sites More sharing options...
shaun786 Posted November 30, 2007 Author Share Posted November 30, 2007 help Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted November 30, 2007 Share Posted November 30, 2007 Uh, a fuse can be purchased at any auto parts store, or somewhere like Wal-Mart or Target. The fuses are in the fuse panels (one under hood and one under the instrument panel). They just pull out and press back in. Quote Link to comment Share on other sites More sharing options...
shaun786 Posted December 1, 2007 Author Share Posted December 1, 2007 So the one under the hood needs to be replaced as well? Quote Link to comment Share on other sites More sharing options...
aarman4 Posted December 1, 2007 Share Posted December 1, 2007 So the one under the hood needs to be replaced as well? I would highly recommend doing a search on google for this information, or reading the manual that came wiht your car if you have it still, or maybe asking almost any of your friends to help you with it, and if not your friends, than any body who has owned a car for longer than 5 years should have experience in this matter. Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted December 1, 2007 Share Posted December 1, 2007 So the one under the hood needs to be replaced as well? If it is blown it will need to be. Also be sure to use the proper amperage fuse, or you will destroy your car! Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted December 3, 2007 Share Posted December 3, 2007 So the one under the hood needs to be replaced as well? hehehe the one thats blown needs replacing! Right side of engine bay in front of the shock tower is the main fuse box, take the lid off and have a look under it, the fuse sizes and their function are shown inside the cover. Other ones in the driver footwell, get down to your toe view and you should see it. Get a circuit tester and test the fuses for the dud circuits, hopefully the new fuse will sort the problem. DO NOT stick a bigger fuse into the holder to try and make it work, as there may be a fault (which caused the fuse to blow) and a short circuit is a great way to start a car fire. Hope your problems a simple one. Quote Link to comment Share on other sites More sharing options...
