Engine Missing
gabelee
93 ES300 started shaking last night almost like engine oil is low low, but when I checked it, levels were good. So then I drove around my neighborhood listening to what sounds like the engine's missing or maybe the fuel injector, or fuel filter is going bad, I don't know? I'm hoping I didn't blow something
but I think if that were to happen, I'd probably know right away. I've got 141,000 miles on the engine, anybody got any ideas, dealt with before?
Gabe
No Check Engine Lights? Is there any hesitation? If one of your cylinders were misfiring a CEL would usually pop up. How's the timing belt?
Yes the CEL light is on. There is no hesitation though. Timing Belt is good, replaced a short while back.
hmmm a 93... try autozone to see if they can retrieve the DTC's and post them up here.
make sure all of your spark plug wires are connected, well, check all of your ignition system's components.
you could have blown a valve.....
did one of your engine mounts break?
all possibilities, if I think of more, ill let you know.
:pirate:
