lexnewb Posted November 8, 2007 Share Posted November 8, 2007 I have a question about my wife's 2000 lexus es300, any input will be appreciated on what can be causing the trouble. My wife told me yesterday that she has had trouble twice in the last week trying to turn on the car. When she turns on the ignition it starts then kind of sputters and dies out. She can keep it on longer by pressing down on the gas and holding it down-idling the car higher. It happened early in the week where it did it for a few minutes-finally turned on and worked fine for 3 days. Then again it did it for about 10 minutes & now is working fine again. There are no check engine or trouble lights on the dashboard so I cannot check w/ an obd device. Is it a bad fuel filter? Again any input is welcomed, Thank you! Quote Link to comment Share on other sites More sharing options...
zockslexus Posted November 8, 2007 Share Posted November 8, 2007 idol control valve? Quote Link to comment Share on other sites More sharing options...
oxfordlexusman Posted December 22, 2007 Share Posted December 22, 2007 idol control valve? My 2001 ES300 is having the same problem. Are you suggesting that the idle control valve is the problem? Do you have any instructions as to how to locate and replace? Quote Link to comment Share on other sites More sharing options...
Lextek1 Posted December 23, 2007 Share Posted December 23, 2007 Idle control valve is sticking. It is under the rubber intake tube where it meets the throttle body. It is repairable! Quote Link to comment Share on other sites More sharing options...
oxfordlexusman Posted December 23, 2007 Share Posted December 23, 2007 Idle control valve is sticking. It is under the rubber intake tube where it meets the throttle body. It is repairable! Thanks ........ I'll give it a try !!!!! Quote Link to comment Share on other sites More sharing options...
oxfordlexusman Posted January 3, 2008 Share Posted January 3, 2008 Idle control valve is sticking. It is under the rubber intake tube where it meets the throttle body. It is repairable! Thanks ........ I'll give it a try !!!!! I located the idle control valve, but instead of dismantling the throttle body and then the idle valve I just squirted the opening of the valve with throttle body cleaner and blew it out with compressed air. I did this a few times and then squirted in some WD-40. After putting back the intake hoses and air cleaner, the car started up a little rough, but once the WD-40 cleared out of the system the car runs great. No more idle problems !!!!!! Quote Link to comment Share on other sites More sharing options...
mburnickas Posted January 3, 2008 Share Posted January 3, 2008 use T-body cleaner next time. Quote Link to comment Share on other sites More sharing options...
oxfordlexusman Posted January 4, 2008 Share Posted January 4, 2008 use T-body cleaner next time. If "T-body cleaner" is throttle body cleaner, that's what I used --- followed by WD-40. B) Quote Link to comment Share on other sites More sharing options...
