I just found out about the existence of this filter, and would like to change it. Does anyone know how to do this, or where instructons can be found. Thge owner's manual doen't even mention it.
Thanks.
  • 2 months later...
The Cabin filter can be located right behind the glove compartment. There's a little piece of the glove compartment that can slide out and the filter is located in a small compartment behind it. Squeeze the tabs and the compartment cover comes off. The filter is in a holder and you just need to pull it down and slide it out. The filter is around $50 at dealer and is very easy to install. Make sure you install the filter in the holder correctly. There's a air flow arrow on the side of the new filter. I did this yesterday in my LS400. Hope it's the same for you.
