dwilder Posted October 31, 2007 Share Posted October 31, 2007 I have a 2000 LS 400 which starting to exhibit starter problems. The battery is brand new and has been tested. Car worked fine until a few weeks ago. The car would not start. Turning the key resulted in very loud clicks coming from the back of the engine (location of the starter). I turned the headlights on and again tried to start the car. Same clicks and no decrease in the intesity of the lights, ergo probably not the battery (confirmed with testing). I had AAA tow the car to a mechanic. He called me the next day and said the car was fine? I got a ride over and sure enough the car started right up. It worked fine for two days, no problem. Sunday AM I jump in the car and no start. I talked to a friend and he mentioned that the security system in the car may not be allowing the starter to engage. I did notice that when I picked the car up from the mechanic all the radio stations had be reset. Accordingly I think there may be something to my friends suggestion. I tried removing the ground cable from the battery for a while. After reconnecting I hit my security key to lock and unlock. The door worked fine, got in the car and still no start. Any recommendations? How can I reset the security in the car? Thanks Quote Link to comment Share on other sites More sharing options...
laney94 Posted November 14, 2007 Share Posted November 14, 2007 I have a 2000 LS 400 which starting to exhibit starter problems. The battery is brand new and has been tested. Car worked fine until a few weeks ago. The car would not start. Turning the key resulted in very loud clicks coming from the back of the engine (location of the starter). I turned the headlights on and again tried to start the car. Same clicks and no decrease in the intesity of the lights, ergo probably not the battery (confirmed with testing). I had AAA tow the car to a mechanic. He called me the next day and said the car was fine? I got a ride over and sure enough the car started right up. It worked fine for two days, no problem. Sunday AM I jump in the car and no start. I talked to a friend and he mentioned that the security system in the car may not be allowing the starter to engage. I did notice that when I picked the car up from the mechanic all the radio stations had be reset. Accordingly I think there may be something to my friends suggestion. I tried removing the ground cable from the battery for a while. After reconnecting I hit my security key to lock and unlock. The door worked fine, got in the car and still no start. Any recommendations? How can I reset the security in the car? Thanks Quote Link to comment Share on other sites More sharing options...
laney94 Posted November 14, 2007 Share Posted November 14, 2007 Have you now been able to reset your security? On my 94ls, you must lock and then unlock the passenger side door with your key. This resets the lockout feature. Quote Link to comment Share on other sites More sharing options...
92silverls400 Posted November 15, 2007 Share Posted November 15, 2007 I have a 2000 LS 400 which starting to exhibit starter problems. The battery is brand new and has been tested. Car worked fine until a few weeks ago. The car would not start. Turning the key resulted in very loud clicks coming from the back of the engine (location of the starter). I turned the headlights on and again tried to start the car. Same clicks and no decrease in the intesity of the lights, ergo probably not the battery (confirmed with testing). I had AAA tow the car to a mechanic. He called me the next day and said the car was fine? I got a ride over and sure enough the car started right up. It worked fine for two days, no problem. Sunday AM I jump in the car and no start. I talked to a friend and he mentioned that the security system in the car may not be allowing the starter to engage. I did notice that when I picked the car up from the mechanic all the radio stations had be reset. Accordingly I think there may be something to my friends suggestion. I tried removing the ground cable from the battery for a while. After reconnecting I hit my security key to lock and unlock. The door worked fine, got in the car and still no start. Any recommendations? How can I reset the security in the car? Thanks Are you sure its the security system? it could be your starter going out, I just had my starter changed couple of month ago, one day my car wouldn't start, just heard it go click, but couple of minutes later, it started up for me. mechanic friend told me the starter maybe going out. finally had it replaced by dealership, car was under warranty. I also have 2000 LS400 Quote Link to comment Share on other sites More sharing options...
