hickory1465 Posted October 24, 2007 Share Posted October 24, 2007 I'm have a burning smell coming from the front tire wheel well area. does not smell like oil, more like grease. I have taken it to the dealer and local garage. I have looked underneath of it with the techs, no axle boots torn. Undercarriage is bone dry, all fluid levels full. Anyone ever have this? Quote Link to comment Share on other sites More sharing options...
lenore Posted October 24, 2007 Share Posted October 24, 2007 Please check your tranmission fluid, make sure it is bright red and not black or burnt smelling.... Quote Link to comment Share on other sites More sharing options...
Grumpa72 Posted October 24, 2007 Share Posted October 24, 2007 Drive the car for a while and then put your hand on the hub of your wheel and see if it is hot. If it is, you either have a caliper not releasing or a brake line that is not allowing the pressure to subside. If either one is your situation, it needs to be remedied. If neither one is, then I would inspect the car while it is on a lift and try to do an up close sniff test to see if you can isolate the area. Gary Quote Link to comment Share on other sites More sharing options...
