Bali26 Posted September 28, 2007 Share Posted September 28, 2007 Hi, I'm a new owner of a 91 LS400 in large part due to this forum. I'm very happy with it so far. There are some things that the car needs done but I just don't have the money to have a lot done, I can barely afford gas. I prefer to buy tools than pay a mechanic. Here are my questions: Biggest problem: The car's giving me only 13 mpg in city. Tyre preasure is maxed out 38 psi but it feels like i'm pulling a trailer. Using 91 octane. What do you think is wrong? Check engine light is ok. Can the Oxy sensors be bad and not show up in check engine? How do I find out if they are bad? I have ramps and can buy oxy sensor socket. All four may need to be replaced? Or front more important than rear? What else can i do to decrease consumption? Alternator? Other problems: TRAC light comes on after a couple minutes of driving and periodic humming sound. Is it ok to ignore it? Very Minor oil leak around oil pan, PS rack area. Oil level stays high. Very minor oil leak around PS pump, area barely moist. Oil level stays high... ok to ignore? Sometimes car blows white smoke when started. Not always. Upper control arm joint a little loose. little play. Ok to ignore for now? Your advice is much appreciated :) Quote Link to comment Share on other sites More sharing options...
