It could be several reasons:
1- slightly warped brake rotor
2- brake glaze
3- tire movement
4- uneven tire pressure
5- unbalanced tire
6- worn suspension components
7- brake pad issues
8- a combination of any of these.
2- brake glaze
3- tire movement
5- unbalanced tire
7- brake pad issues
/\ /\ /\ what he said. Hopefully your front end is okay also and you don't have a busted control arm or damaged tierods. Take it to Tire Kingdom and let them check it out... any of these repairs need attention. good luck ;)
oh and he forgot BENT WHEEL :P
2- brake glaze
3- tire movement
5- unbalanced tire
7- brake pad issues
The amount of the bend in the rim is referred to as movement. (# 3 on the list) All rims have a certain amount of "movement" in them. When a rim is bent or out of round, then the tire movement becomes out of spec and then needs to be replaced. :P ..... LOL!!!!
