Running Board Light Replacement
new2th4me
They want $75 for the light alone! Is it a bulb? When only 1 light on the side goes out, gives the care a "broken" look.... Any suggestions?
There are two kinds of lights on the boards. One is the long ones you see from the side that light to top surface. Another are small round ones on the bottom that illuminate the ground. I presume the $75 bulb is for the long, top ones? $25 for installation isn't bad. The manual shows that the bulbs are just as long as you see in the lights, but the impression I get is you might have to remove the running board to change the bulb. My dealer charges a minimum 0.5 hrs to do anything, so that would be $47.50 in labor vs. $25 for your dealer. I would go w/ sliders painted to match the vehicle on the tube part and black on the flat part. They will actually protect the vehicle body if you offroad, but no whiz-bang look like the OEM boards.
http://www.sleeoffroad.com/products/UZJ_sliders_main.htm (P/N SOF1061)
