Cd Player
I have an RX350 with a 6 cd changer. When you have all 6 discs loaded can you play a seventh cd or are you limited to the 6 in the player. I can find no information in the manual.
No, you can't load a 7th cd - you are limited to the 6 in the player. But, you can compress your cd's into mp3's and have the equivalent of about 60 cd's loaded.
-Ken
-Ken
Not sure if this is common knowledge but, I use a CD-RW instead of a CD-R for the mp3s. It works the same. So when you're bored of the cd, instead of tossing it out, you can burn over it.
While we're on the CD issue, if the Text button is on, should it be able to display the titles of the tracks either on the CD display and/or the navigation screen? I bought 2 CDs at Barnes and Noble and none of this info shows up.
I looked in the manual but it is confusing because it also talks about models with DVD in the back, which I don't have.
