Changing The Light On 01 Is300
wasabi01
Open your trunk
There are two circular clips that you need to take out so that you can access the screws. Once you get those off. Slightly lift up and it will start comming out.
DO NOT PULL DOWNWARD
Pull it a little up and to the left for the left housing, or right housing. It should all come off. There will be a big circle that you have to turn. and then you will get access to the light bulb.
Open your trunk
thanks bartkat, i'll try it and see what happen
