ZZ4 Posted September 1, 2007 Share Posted September 1, 2007 Does anyone know if there is a way to disable the Seat Belt warning chime (besides buckling the Seat Belt) in a 2008 RX350? Manny Gonzalez posted a procedure which included pushing a "Start" button, but I have no Start button. Thanks! Quote Link to comment Share on other sites More sharing options...
azobairi Posted September 2, 2007 Share Posted September 2, 2007 It goes away after maybe 45 seconds or so - pretty annoying for that initial period but it will silence itself if you wait for it. Quote Link to comment Share on other sites More sharing options...
Crystal_white_RX350 Posted November 8, 2007 Share Posted November 8, 2007 Here is the instruction that is posted in this site for reseting seat belt buzzers; 1. Turn the ignition switch to ON position 2. Press the ODO/Trip switch until the odometer display "ODO" 3. Turn the ignition switch off. 4. Turn the ignition switch to the ON position. 5. Press the ODO/Trip switch immediately (within 6 seconds) and hold it down for 10 seconds or more. 6. Continue holding down the ODO/trip switch and fasten the driver side seat belt. 7. Check that the odometer display either "b-on" or "b-off". 8. Press the ODO/Trip switch to change the display to "b-off". 9. Turn ignition switch off. 10. You are done. Quote Link to comment Share on other sites More sharing options...
