Cigarette Lighter
808-lexus
it doesn't even get hot. and how do i get to the fuses? :blink:
sorry, i'm really a novice at cars....
Look under the parking break release and above the car pedals on the left (towards the door). You'll see a fuse panel cover. Pull the cover and look at the diagram on the cover. There is a fuse designated for that circuit. Pull it, see if its blown, if so replace it with a fuse of the same voltage as dictated on the fuse itself.
ok, i took the fuse out and, sure enough, it was blown! went to the part store and bought the fuse, replaced it, and now it works!!! :lol:
thank you for your help!!! :D
for future situations similar to this: any time you have an electrical component or system in the car that simply quit working, or never worked, check your fuses first. It can save you hours...trust me...
