Ccurtin Posted August 26, 2007 Share Posted August 26, 2007 I notice at 60MPH+ the front hood bounces up and down a little. It seems to be closed correctly. is there an adjustment or is there a part worn out? car has only 40k miles on it. FYI, I just bought new struts for the trunk on ebay and they work great. Easy to install too. Quote Link to comment Share on other sites More sharing options...
Intune Posted August 27, 2007 Share Posted August 27, 2007 I notice at 60MPH+ the front hood bounces up and down a little. It seems to be closed correctly. is there an adjustment or is there a part worn out? car has only 40k miles on it.FYI, I just bought new struts for the trunk on ebay and they work great. Easy to install too. Did you get the Fig Engineering struts? My 01 trunk is a bear to lift and it comes down really hard & fast. I'll take a look at my hood tomorrow on the hwy. Quote Link to comment Share on other sites More sharing options...
glenmore Posted August 27, 2007 Share Posted August 27, 2007 When I test drove my 1990 LS400 before buying it, I noticed the hood shook a lot. Turns out the engine mounts were near kaput and changing them solved the problem. glenmore 19901 lS400 1991 300CE 2000 C280 Quote Link to comment Share on other sites More sharing options...
Ccurtin Posted August 27, 2007 Author Share Posted August 27, 2007 I notice at 60MPH+ the front hood bounces up and down a little. It seems to be closed correctly. is there an adjustment or is there a part worn out? car has only 40k miles on it.FYI, I just bought new struts for the trunk on ebay and they work great. Easy to install too. Did you get the Fig Engineering struts? My 01 trunk is a bear to lift and it comes down really hard & fast. I'll take a look at my hood tomorrow on the hwy. I got the FIG trunk struts on ebay-installed easy and now the trunk goes up and down a lot better. thanks for checking on front hood vibration for me. Quote Link to comment Share on other sites More sharing options...
Intune Posted August 28, 2007 Share Posted August 28, 2007 C, no vibration at 60-65. At 70-75 I get some wind flexing where I can see the sheet metal being depressed by the pressure but no rattles. The hood is very solid when I try to push it down in the front & sides and with it raised there is no side to side movement. Did you take a look at your weather stripping/seals? With your new trunk struts, if you pull the lid about halfway down & let go does it slam or come down slowly? Thanks! Quote Link to comment Share on other sites More sharing options...
Ccurtin Posted September 1, 2007 Author Share Posted September 1, 2007 C, no vibration at 60-65. At 70-75 I get some wind flexing where I can see the sheet metal being depressed by the pressure but no rattles. The hood is very solid when I try to push it down in the front & sides and with it raised there is no side to side movement. Did you take a look at your weather stripping/seals?With your new trunk struts, if you pull the lid about halfway down & let go does it slam or come down slowly? Thanks! Trunk comes down slowly with the fig. All the seals look in great shape under the hood. Hood will flex slightly on corners when closed. I see a slight vibration on the front hood at 65+ mph. weird. Quote Link to comment Share on other sites More sharing options...
