Help Needed For Radar Install
jdonnelly
Hi:
I would like to tap into the wires up in the sunroof control aera for a radar detector (V1). I want to find a wire that is ignition switched. I also could use a tip on how to remove the plastic to get to the wires. The car is a 2007 RX
Thanks
Jeff
Tap directly off of the cigarette lighter plug (easiest way to find hot in acc, and ground- by just pulling out the metal cyl.) and run thin wires up the pillar and under the roof liner. You can squeeze the wire to make it hidden. That's what i would suggest.
