trickshot11 Posted August 16, 2007 Share Posted August 16, 2007 So I recently discovered that I have a crack in my 93' ES300 engine :cries: ....my mechanic sugested a cheaper alternitive to buying a different Lexus motor and trying a Camry motor....Is this even possible???...if so what years would be swapable? Quote Link to comment Share on other sites More sharing options...
Toysrme Posted August 18, 2007 Share Posted August 18, 2007 you own a 1993 toyota camry with better trim on it. you can use a 92-93 camry/ES/windom v6. the cost of them is identical as they both come from the toyota parts chain. (just under 2 grand) if replacing i would use a japanese import to replace it for $500-700. what do you mean by crack??? Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted August 18, 2007 Share Posted August 18, 2007 same car... same engine... camry motor/es300 motor same motor... i think its a 3VZ FE Quote Link to comment Share on other sites More sharing options...
trickshot11 Posted August 19, 2007 Author Share Posted August 19, 2007 you own a 1993 toyota camry with better trim on it. you can use a 92-93 camry/ES/windom v6. the cost of them is identical as they both come from the toyota parts chain. (just under 2 grand)if replacing i would use a japanese import to replace it for $500-700. what do you mean by crack??? By crack I mean that there was a crack in the block from overheating that allows all the coolant to leak into oil Where would I find a listing of these Jap imports? or a place that sells them Quote Link to comment Share on other sites More sharing options...
trickshot11 Posted August 20, 2007 Author Share Posted August 20, 2007 you own a 1993 toyota camry with better trim on it. you can use a 92-93 camry/ES/windom v6. the cost of them is identical as they both come from the toyota parts chain. (just under 2 grand)if replacing i would use a japanese import to replace it for $500-700. what do you mean by crack??? ...your inbox is full so i sent this here instead....guy at the garage show it too me....dont think it came from me...i just recently bought it and it most likely had a small crack already wich is why my coolant was alaways disapearing but not leaving puddles it just got worse over time and is now visible...thanks for the info! Quote Link to comment Share on other sites More sharing options...
Toysrme Posted August 21, 2007 Share Posted August 21, 2007 ok. it should have never been put in with a crack to begin with. ? that's just being wierd. Quote Link to comment Share on other sites More sharing options...
