ko90ls Posted August 15, 2007 Share Posted August 15, 2007 alright guys and gals, going to check valves while TB/WP is being done. Bought cheap tool off ebay even though monarch says it's not the best. hopefully digicam will pop up and pics can be taken. But in the mean time my fan clutch nuts are not budging. WD-40 did nothing, new 12mm wrench and lexus wrench from trunk are being use to remove. I was thinking about taking the whole fan pulley off and then getting the clutch but the pulley won't budge either. do i need to tap it with a rubber mallet to break seal? I already removed 3 12mm bolts and 14mm bolt. waiting on chain wrench to remove crankshaft. should this be removed first? Thanks in Advance! Quote Link to comment Share on other sites More sharing options...
