matt_m427 Posted August 13, 2007 Share Posted August 13, 2007 I just ran a code diagnostic on my 1993 LS400 and came up with code 24 and 31. 24 - Intake air temperature sensor signal. 31 - Air flow meter signal. Prior to the check engine light appearing I removed the MAF and attempted to clean it with a bottle of MAF cleaner. I let the MAF dry for an hour, installed it, then went to crank up the car. When it started up, it began running at +- 300rpms and stalled and stuttered under any spirited acceleration . I've just replaced the plugs, wires, and fuel filter, so my question is, should I just purchase a new MAF assembly and see if that will remedy the problem? Thanks for any advice... - Matt Quote Link to comment Share on other sites More sharing options...
matt_m427 Posted August 15, 2007 Author Share Posted August 15, 2007 *bump* Quote Link to comment Share on other sites More sharing options...
ko90ls Posted August 15, 2007 Share Posted August 15, 2007 found this searching, http://us.lexusownersclub.com/forums/index...+intake+chamber Good Luck! Quote Link to comment Share on other sites More sharing options...
matt_m427 Posted August 15, 2007 Author Share Posted August 15, 2007 Thank you! Quote Link to comment Share on other sites More sharing options...
