topichka Posted August 13, 2007 Share Posted August 13, 2007 Hi all, I've got a 2001 GS430 with some noises...I think it's coming from the front wheels and I'm guessing it's the wheel bearings. However, I'm a bit confused. My left rear wheel bearing went bad a while back. It made an a humming noise, increasing to a peak around 35 mph and most notable while turning right it increase in volume then decrease when turning left or when I increased speed. My front seems like it's making the same noise except for the fact it happens at higher speeds--closer to 45-50 mph and doesn't seem to increase or be more noticeable when I turn either direction. Does this sound like a wheel bearing problem to you? I kind of assumed since the rear went bad, then it doesn't seem unreasonable that the front's might go bad as well but I assumed it would happen at the same speeds and have the same characteristics as the rear. It's rather expensive to fix them without knowing if this is the issues or not so I'm trying to get some other, more experienced opinions. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Boost_Junkiee Posted August 14, 2007 Share Posted August 14, 2007 Hi all,I've got a 2001 GS430 with some noises...I think it's coming from the front wheels and I'm guessing it's the wheel bearings. However, I'm a bit confused. My left rear wheel bearing went bad a while back. It made an a humming noise, increasing to a peak around 35 mph and most notable while turning right it increase in volume then decrease when turning left or when I increased speed. My front seems like it's making the same noise except for the fact it happens at higher speeds--closer to 45-50 mph and doesn't seem to increase or be more noticeable when I turn either direction. Does this sound like a wheel bearing problem to you? I kind of assumed since the rear went bad, then it doesn't seem unreasonable that the front's might go bad as well but I assumed it would happen at the same speeds and have the same characteristics as the rear. It's rather expensive to fix them without knowing if this is the issues or not so I'm trying to get some other, more experienced opinions. Thanks in advance! Do you have aggressive tread pattern tires? or get new tires? Usually most complaints I get are a humming noise that ends up being the tires. A wheel bearing will groan louder when loaded, like when you turn side to side. Quote Link to comment Share on other sites More sharing options...
topichka Posted August 15, 2007 Author Share Posted August 15, 2007 Hi all,I've got a 2001 GS430 with some noises...I think it's coming from the front wheels and I'm guessing it's the wheel bearings. However, I'm a bit confused. My left rear wheel bearing went bad a while back. It made an a humming noise, increasing to a peak around 35 mph and most notable while turning right it increase in volume then decrease when turning left or when I increased speed. My front seems like it's making the same noise except for the fact it happens at higher speeds--closer to 45-50 mph and doesn't seem to increase or be more noticeable when I turn either direction. Does this sound like a wheel bearing problem to you? I kind of assumed since the rear went bad, then it doesn't seem unreasonable that the front's might go bad as well but I assumed it would happen at the same speeds and have the same characteristics as the rear. It's rather expensive to fix them without knowing if this is the issues or not so I'm trying to get some other, more experienced opinions. Thanks in advance! Do you have aggressive tread pattern tires? or get new tires? Usually most complaints I get are a humming noise that ends up being the tires. A wheel bearing will groan louder when loaded, like when you turn side to side. No, I have Yoko. Avid v4s I think. I've had the tire before with no noticeable noises....Thanks for you thoughts though... Quote Link to comment Share on other sites More sharing options...
Boost_Junkiee Posted August 17, 2007 Share Posted August 17, 2007 I would still suggest that you rotate them just as process of elimination. Quote Link to comment Share on other sites More sharing options...
topichka Posted August 19, 2007 Author Share Posted August 19, 2007 Thanks--that's a good idea--I'll do that tomorrow and see what happens. Quote Link to comment Share on other sites More sharing options...
