glr Posted August 7, 2007 Posted August 7, 2007 Have put on about 70k of enjoyable miles on my '04 ES330. I change my own oil regularly but have never replaced the transmission fluid and am unsure of the procedure. As a DIY job how would you rate the difficulty? I did a search and hopefully did not overlook a desciption of the procedure and finally, do I need to replace a filter too? Thanks in advance for guidance. Regards, Greg
lenore Posted August 7, 2007 Posted August 7, 2007 Look under the RX300 forums, the ES has to be similar, many have given that procedure. Make sure to use correct fluid. In the older RX300 Toyota Type IV fluid is the choice. (can be bought at Toyota dealerships cheaper) The filter inside can be changed and the Lexus has a drain plug for the tranny fluid...
lenore Posted August 7, 2007 Posted August 7, 2007 found this for reference http://mywebpages.comcast.net/rx300how2/xm...uid_change1.htm Gives you an idea of the ease of changing fluid, Sorry it is an RX but should be similar.....good luck
