Changing Transmission Fluid On Es330...diy Job?
glr
Have put on about 70k of enjoyable miles on my '04 ES330. I change my own oil regularly but have never replaced the transmission fluid and am unsure of the procedure. As a DIY job how would you rate the difficulty? I did a search and hopefully did not overlook a desciption of the procedure and finally, do I need to replace a filter too?
Thanks in advance for guidance.
Regards,
Greg
Look under the RX300 forums, the ES has to be similar, many have given that procedure. Make sure to use correct fluid. In the older RX300 Toyota Type IV fluid is the choice. (can be bought at Toyota dealerships cheaper) The filter inside can be changed and the Lexus has a drain plug for the tranny fluid...
