RotaryAE86 Posted August 5, 2007 Share Posted August 5, 2007 ok, heres the deal my 92 ls400 i bought came from the factory with air ride but was converted to OEM shock/spring. well im putting oem air ride back in it and i need to know where the compressors are and where the air lines hook up to on the air struts so i can see if they just pulled the struts and disconnected sensors or removed everything in the system. i just got done pulling the back seat and there was a connector on top of the rear strut...... anyways any pics or links would be greatly appreciated i searched and frustratingly enough could not find anything. thanks in advance. -Dutch Quote Link to comment Share on other sites More sharing options...
LexChamp Posted August 5, 2007 Share Posted August 5, 2007 ok, heres the deal my 92 ls400 i bought came from the factory with air ride but was converted to OEM shock/spring. well im putting oem air ride back in it and i need to know where the compressors are and where the air lines hook up to on the air struts so i can see if they just pulled the struts and disconnected sensors or removed everything in the system. i just got done pulling the back seat and there was a connector on top of the rear strut...... anyways any pics or links would be greatly appreciated i searched and frustratingly enough could not find anything. thanks in advance.-Dutch Hey good luck! I usually hear people trying to get rid off them, not put them back. I have a 95 LS with air Sus; I'm very close to getting rid off it. The rear drive side is sagging down. Why are you going back and did you find a good deal on the Air suspension struts? Quote Link to comment Share on other sites More sharing options...
RotaryAE86 Posted August 5, 2007 Author Share Posted August 5, 2007 ok, heres the deal my 92 ls400 i bought came from the factory with air ride but was converted to OEM shock/spring. well im putting oem air ride back in it and i need to know where the compressors are and where the air lines hook up to on the air struts so i can see if they just pulled the struts and disconnected sensors or removed everything in the system. i just got done pulling the back seat and there was a connector on top of the rear strut...... anyways any pics or links would be greatly appreciated i searched and frustratingly enough could not find anything. thanks in advance.-Dutch Hey good luck! I usually hear people trying to get rid off them, not put them back. I have a 95 LS with air Sus; I'm very close to getting rid off it. The rear drive side is sagging down. Why are you going back and did you find a good deal on the Air suspension struts? yeah, i found a good deal on the struts thats why i want to go back to air ride. i want to have it slammed while parked and normal ride height while driving. besides i can get new struts for about 200 a piece which isnt bad when you consider what dealer struts cost. Quote Link to comment Share on other sites More sharing options...
LexChamp Posted August 5, 2007 Share Posted August 5, 2007 ok, heres the deal my 92 ls400 i bought came from the factory with air ride but was converted to OEM shock/spring. well im putting oem air ride back in it and i need to know where the compressors are and where the air lines hook up to on the air struts so i can see if they just pulled the struts and disconnected sensors or removed everything in the system. i just got done pulling the back seat and there was a connector on top of the rear strut...... anyways any pics or links would be greatly appreciated i searched and frustratingly enough could not find anything. thanks in advance.-Dutch Hey good luck! I usually hear people trying to get rid off them, not put them back. I have a 95 LS with air Sus; I'm very close to getting rid off it. The rear drive side is sagging down. Why are you going back and did you find a good deal on the Air suspension struts? yeah, i found a good deal on the struts thats why i want to go back to air ride. i want to have it slammed while parked and normal ride height while driving. besides i can get new struts for about 200 a piece which isnt bad when you consider what dealer struts cost. I've seen rear struts remanufactured for that same price $200 but not for the fronts. How much are you getting the fronts for? And where? Thanks. Quote Link to comment Share on other sites More sharing options...
RotaryAE86 Posted August 5, 2007 Author Share Posted August 5, 2007 im getting them used from ppl who have upgraded, i was just saying that rebuilt struts arent that bad when the time comes. Quote Link to comment Share on other sites More sharing options...
