TwoToneLex Posted July 25, 2007 Share Posted July 25, 2007 Does anyone know if I add this down pipe Down Pipe will I have to change my exhaust manifold at all or is it just a bold on without any further modifications? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted July 25, 2007 Share Posted July 25, 2007 Does anyone know if I add this down pipe Down Pipe will I have to change my exhaust manifold at all or is it just a bold on without any further modifications? You're kind of asking a trick question here. If you want to know if that down pipe will fit your stock system, I don't see any reason why not. But when ever you mix new exhaust parts with used ones, your gonna have to do some modifying. All the sections of your exhaust have expanded and contracted, shifted and slightly bent to fit tight when it was put together new. So, especially a mid section pipe, will not just bolt in. Also, if your thinkin that you will get a 10-16 hp increase by using this down pipe alone, well, , I don't think so. You'll definately need to finish the exhaust system from the down pipe to the back to see any gains worth the trouble. Quote Link to comment Share on other sites More sharing options...
