LexChamp Posted July 19, 2007 Share Posted July 19, 2007 95 LS 174,000 I will be replacing all 4 O2 Sensors on my LS today. After replacing the sensors, does the computer has to be reset. Usually when I disconeect the battery, the engine light goes out for a bout a week but than returns. Should I take the car to somewhere to have the code reset after having the sensors replaced. Thanks Quote Link to comment Share on other sites More sharing options...
larryp Posted July 19, 2007 Share Posted July 19, 2007 As you discovered, disconnecting the battery will do a reset, however, if the CEL is related to the O2 sensors, i believe the computer will reset itself once it detects the proper O2 mix (signal) from the new sensors. Quote Link to comment Share on other sites More sharing options...
sonyman Posted July 20, 2007 Share Posted July 20, 2007 The only reason for the MIL to illuminate after disconnecting the battery would be if the fault reoccurs. If the new sensors fix the issue, disconnecting the battery should clear the code permanently. Quote Link to comment Share on other sites More sharing options...
LexChamp Posted July 21, 2007 Author Share Posted July 21, 2007 The only reason for the MIL to illuminate after disconnecting the battery would be if the fault reoccurs. If the new sensors fix the issue, disconnecting the battery should clear the code permanently. After replacing all 4 Sensors, the battery was disconnected. Drove the car for a while; took it Advance Auto for a free Diagnostic; Everything was perfect. Cost $ 4 sensors $ 220 plus $45 labor. I'm glad its done. Quote Link to comment Share on other sites More sharing options...
