well i cleaned the iavc for my sister's car (only took off the black plastic piece and sprayed the inlet leading to the iavc till the magnetic rod spinned freely)
cleaned the throttle body while i was at it
at first, the car started and drove fine
just the normal hesitation from cleaning the throttle body at first
i noticed the idle was acting up a little
the next day, it just kept stalling
it would fire it up, but then the idle would drop and it'd stall
i would have to keep my throttle on the gas till the car got up to temp, then it would be fine
i was going to tighten up the throttle cable and raise the idle to see if that would help but couldnt find the screw
anyone have any ideas?
im stumped
thanks
The ecu controls the idle ., it sounds like it is still sticking and needs some more cleaning by removing it and cleaning it.
really?
i sprayed a generous amount of cleaner on it until the rod spun freely
it was very hard to move around before
i managed to strip a screw while removing the black cover/plug leading to the IAVC
is it possible that its not aligned correctly, leading to this problem?
also, would replacing the washer on the rod the wrong way cause a problem too?
really?
anymore ideas???
It sounds like you might have an air leak in there somewhere. Did you reassemble everything tight? Any cracks in the ducting? Did you get all the vacuum lines on correctly? A little air leak in the intake can cause all sorts of sporadic idling/starting issues.
i thought it might be a vacuum leak
from what i can remember, the black plastic piece in front of the iavc was tight but im not sure if it was aligned properly
it should be as there is a small chance of error
all other air lines were properly clamped and tightened
The reason I mention it is because I've seen posts where people have the same symptoms and it ended up being a hairline crack in the bellows ducting or a hose that they couldn't see until they squeezed it and it opened.
It could also be a ton of other things... it could be the ICV still sticking. It could be a MAF that's losing it's mind. It could be a clogged fuel filter. It could be a cracked intake that seals up upon thermo expansion when it comes up to temperature. It could be problems with the injectors. Again, it could be a lot of things. With a 'gremlin' like that, you really need to find a talented mechanic who can diagnose your problem, and hopefully get it right the first time.
Ahh if the tps is broken then there might be a problem, you need to do a leak test.
Spary a small amount of water at the area to see if it is sucked in under light throttle
damn, sounds like a nightmare
well ill disassemble everything
anyone know what type of screw i need for the black plastic part in front of the iavc?
guess im going to have to drill and tap one of the screws
hopefully i didnt overtorque any parts and cause a crack
im pretty sure lexus wouldn't produce such inferior parts that it would crack under such light pressure
hopefully it isnt anything serious cause that would suck big time
weird thing was all parts were working properly before i attempted the cleaning
now its just gone downhill
Before you go ahead to do all sorts of things, just first reset the EFI fuse in the fusebox. Pull it out for about 30 secs and put back with engine and all accessories off. Having cleaned the IACV its now freer and lighter thus reset would help the ECM recalculate the present condition.
