TampaLS460 Posted July 13, 2007 Share Posted July 13, 2007 Hello, New to the board and I was wondering if any of you have experienced this same issue? I have a new LS460 with approx 1400 miles about a month old. When parking or turning slow I'm noticing a dull "pop" type sound-almost like linkage connecting or moving together. Someone mentioned they though it could be the Brake Calipers. I'm taking it into the dealership tomorrow morning to have it checked out. Thanks Quote Link to comment Share on other sites More sharing options...
DArustik Posted July 13, 2007 Share Posted July 13, 2007 never heard of this problem...its probabaly just a defect with your car. Lexus should take care of it for you. Quote Link to comment Share on other sites More sharing options...
TampaLS460 Posted July 15, 2007 Author Share Posted July 15, 2007 Hello,New to the board and I was wondering if any of you have experienced this same issue? I have a new LS460 with approx 1400 miles about a month old. When parking or turning slow I'm noticing a dull "pop" type sound-almost like linkage connecting or moving together. Someone mentioned they though it could be the Brake Calipers. I'm taking it into the dealership tomorrow morning to have it checked out. Thanks UPDATE: I spoke to the service advisor who seemed to be well aware of the problem-he took over the description of the problem mid-way through my explination. He stated that it was an issue with the springs in the front-end and that they would have to replace some rubber bushings, he also made the comment that Lexus was aware of the issue and that there was talk of Lexus redesigning a new sping later this year, but nothing definite at this point. I'll update after the repair Quote Link to comment Share on other sites More sharing options...
TampaLS460 Posted August 3, 2007 Author Share Posted August 3, 2007 Hello,New to the board and I was wondering if any of you have experienced this same issue? I have a new LS460 with approx 1400 miles about a month old. When parking or turning slow I'm noticing a dull "pop" type sound-almost like linkage connecting or moving together. Someone mentioned they though it could be the Brake Calipers. I'm taking it into the dealership tomorrow morning to have it checked out. Thanks UPDATE: I spoke to the service advisor who seemed to be well aware of the problem-he took over the description of the problem mid-way through my explination. He stated that it was an issue with the springs in the front-end and that they would have to replace some rubber bushings, he also made the comment that Lexus was aware of the issue and that there was talk of Lexus redesigning a new sping later this year, but nothing definite at this point. I'll update after the repair UPDATE: The initial fix was going to be to install "dampers"-rubber sleeves over the front coil springs. After several days I was told that Lexus had provided the new designed coil springs and the dealer would be installing these instead of the dampers. I've had the car back for 4 days and no more front end noise. Quote Link to comment Share on other sites More sharing options...
DArustik Posted August 4, 2007 Share Posted August 4, 2007 never heard of this problem...its probabaly just a defect with your car. Lexus should take care of it for you. I take that back...heard of the problem also exists in new IS models!! sorry guys! Quote Link to comment Share on other sites More sharing options...
malexus Posted August 7, 2007 Share Posted August 7, 2007 Hi: I got a new LS460 two weeks ago, and began to hear a similar noise since 3-4 days ago. I called the dealer but they don't seem to know, and told me it's normal due to fuel injector. Fortunately, I found your posting. I was very surprised that only you and I had this problem. The noise definitely cannot be tolerated. I sent my dealer your posting and hope that they can recongnize it. Is it true after the car is driven for a while, the noise decreases, which is my impression. I want to make sure my dealer can reproduce the problem so they will fix it. I will probably have to leave the car overnight. How did you get them to reproduce it? Thanks --Ma ___________________________________ Hello,New to the board and I was wondering if any of you have experienced this same issue? I have a new LS460 with approx 1400 miles about a month old. When parking or turning slow I'm noticing a dull "pop" type sound-almost like linkage connecting or moving together. Someone mentioned they though it could be the Brake Calipers. I'm taking it into the dealership tomorrow morning to have it checked out. Thanks UPDATE: I spoke to the service advisor who seemed to be well aware of the problem-he took over the description of the problem mid-way through my explination. He stated that it was an issue with the springs in the front-end and that they would have to replace some rubber bushings, he also made the comment that Lexus was aware of the issue and that there was talk of Lexus redesigning a new sping later this year, but nothing definite at this point. I'll update after the repair UPDATE: The initial fix was going to be to install "dampers"-rubber sleeves over the front coil springs. After several days I was told that Lexus had provided the new designed coil springs and the dealer would be installing these instead of the dampers. I've had the car back for 4 days and no more front end noise. Quote Link to comment Share on other sites More sharing options...
