fortIs Posted July 3, 2007 Posted July 3, 2007 Does anybody know how much the dealer will charge to program new sensors?
terry993 Posted July 3, 2007 Posted July 3, 2007 I did it once with the existing ones after I got a flat. Not that difficult with the manual. Maybe it is a dealer-only job with new ones.
chumleyIS250M/T Posted July 11, 2007 Posted July 11, 2007 Just had to replace a sensor due to broken valve stem. $220 total. $120 for sensor, $100 for flat tire/reprogram. Reprogramming is only necessary when there is a new sensor added in.
fortIs Posted July 13, 2007 Author Posted July 13, 2007 Just had to replace a sensor due to broken valve stem. $220 total. $120 for sensor, $100 for flat tire/reprogram. Reprogramming is only necessary when there is a new sensor added in. Does anyone know if Toyota valve stems will work with the lexus?
Motoracer Posted July 14, 2007 Posted July 14, 2007 Does anybody know how much the dealer will charge to program new sensors? I bought 17" winter wheels and tires for my '07 IS350 at Direct Tire (Natick, MA). We discovered that the Lexus has not made the programming equipment available to independent shops, so I had to take it to Lexus of Watertown where they programmed the sensors for $100.
jomon Posted July 17, 2007 Posted July 17, 2007 Does anybody know how much the dealer will charge to program new sensors? I bought 17" winter wheels and tires for my '07 IS350 at Direct Tire (Natick, MA). We discovered that the Lexus has not made the programming equipment available to independent shops, so I had to take it to Lexus of Watertown where they programmed the sensors for $100. Where exactly is the TPMS located on the wheel?
bartkat Posted July 18, 2007 Posted July 18, 2007 Theyre integral with the valve stems. If you look you'll see that the stems are metal instead of rubber. The TPMS part is attatched to that inside the wheel.
