I believe I've found all the opinions I can expect on this topic elsewhere on this website. But as a new Lexus owner, any other important new owner info from you experienced ones would be great to know, too, especially regarding the 2003 ES300.
Thanks!
The lowest you can run without experiancing pinging. Reset your ECU & start with 87. If it pings reset again & go upwards to 89-91.
As you can see it is designed to run 91 octane, however it will run peachy on 87. Same as the Camry's 1mz-fe w vvt-i was rated for. =D
