homemechanic Posted June 26, 2007 Share Posted June 26, 2007 Please suggest how to fix a rim (wheel) leak. Couple months ago my tire had a nail in it. Pulled and patched. A week later, it started to leak air. The guy at Costco installed a new valved, but that didn't help. I went to another Costco and this technician was more experience. He brushed the rust off and beaded the rim with a compound before putting the tire back on. That was good for several months. Now it starts to leak air again. Using soap and water, I detected the leak where the tire beads into the rim. Any suggestions on how to fix this leak? Had anyone tried installing an inner tube rather than buying a new rim (wheel)? I see Kragen sells these Victor/Monkey Grip inner tubes for tires. I know bicycles use inner tubes, but don't know if this would be beneficial for car tires. Thanks a lot! Vehicle: 99 ES300 with chrome wheels Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted July 24, 2007 Share Posted July 24, 2007 homemechanic, The leak might be from a bent rim lip? If yes the question is it worth the cost of repairing, here is a link that may help with your decision. Another problem is pinholes in the aluminum that make air leak from the tires. This process requires dismounting the tire from the rim and sealing the pinholes. http://automedia.com/Aluminum_Wheel_Repair/ccr20021201aw/1 http://www.thecarconnection.com/Enthusiast...A9164.html?pg=1 Quote Link to comment Share on other sites More sharing options...
mastertech Posted July 25, 2007 Share Posted July 25, 2007 the beads need to be cleaned on the tire and the rim,then resealed with bead sealer.. he prob just did a half azzed job since the poor kids there get $7.00 to slave tires all day,,, Quote Link to comment Share on other sites More sharing options...
mastertech Posted July 25, 2007 Share Posted July 25, 2007 oh and I use a big very heavy duty wire brush on the rubber bead of the tire and rim Quote Link to comment Share on other sites More sharing options...
mastertech Posted July 25, 2007 Share Posted July 25, 2007 oh and I use a big very heavy duty wire brush on the rubber bead of the tire and rim I would never use a tube.. I don't see it ever balancing out well.. it can be fixed it just has to be done right... Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 25, 2007 Share Posted July 25, 2007 Green slime should also work well. Quote Link to comment Share on other sites More sharing options...
mastertech Posted July 25, 2007 Share Posted July 25, 2007 Green slime should also work well. green slime is a band aid not a repair.... Quote Link to comment Share on other sites More sharing options...
mastertech Posted July 25, 2007 Share Posted July 25, 2007 oh and sk I love your car,, its sweet... Quote Link to comment Share on other sites More sharing options...
