Odd, the master key won't unlock the lid. The key slides into the lock fine but won't turn. Any ideas?
If you look to the left of the steering wheel down beneath the air vent between the trunk release and the fuel door release theres a keyhole inside a button, try putting the master key in there and turning it. Thats the valet lockout.
If thats not it then the lock cylinder must be jammed.
Thanks, I'll check that again but I thought that only prevents the electronic trunk release from functioning?
