kayexelate Posted June 13, 2007 Share Posted June 13, 2007 Hi there, I have a 2002 GS 300. I have the stock rims and tires on them and want to change them out for the G-spider rims. I was going to order the 18x8 rims from Sewell Lexus: http://beta.lexus-parts.com/parts_detail.asp?id=88797 Seems like a good price. Would the 18x8.5 be too wide for my GS? I don't want anything that sticks out, so I think the 18x8 is the way to go (I presume that doesn't stick out), but I wanted to double check w/you experts out there. Also, what size tire should I get? I was told 245/40/18 would be best for this on my car (I didn't lower it or put in anything different). So I want to make sure that the tires don't rub against the wheel well or anything else. I received mixed messages from different Lexus Dealerships. Some said it would be fine and no problem. Another said they tried another car for a customer and they rubbed on the shock towers. Would there still be a big "gap" in between the top of the tire and the fender/wheel well? I presume any "gap" would be smaller than what I have now. Would the diameter be 2 inches less than what I have now (16" changing to 18") or would the tires for the 18" have a smaller "thickness" so as the overall diameter for the whole wheel + tire would not necessarily be 2 inches more with an 18" rim than a 16" rim. (I hope I explained my question correctly). Basically I want the tires to "fill" the wheel well a bit more so that when someone is looking from the side, there is less of a "Gap". But again, without having to lower or modify anything excpet buying new rims and tires. Thanks for your help ahead of time. Quote Link to comment Share on other sites More sharing options...
Doja Posted June 16, 2007 Share Posted June 16, 2007 There might be a slight drop, but the 16" wheels have thicker tires, and the 18" ones have tires that are about half as thick. Your best bet would be a lowering kit like an inch or so. Quote Link to comment Share on other sites More sharing options...
