yaupoman Posted August 31, 2003 Share Posted August 31, 2003 1998 ES300. I notice when I trun on the air conditioning, the two fans off the radiators will engage and start. It kind of make a loud noise. Is it normal? The airconditioning works fine I think. It usually starts with a blast of air at higher spped and then it settles down to a lower speed. Alos, when I step on the gas, the fan speeds up as well, is this normal? Thanks. Quote Link to comment Share on other sites More sharing options...
bbsal Posted August 31, 2003 Share Posted August 31, 2003 yes thats perfectly normal!mine does the same thing.when you use the air condition it puts more strain on the motor and makes it hotter so the fan kicks up a notch when you hit the gas. :D Quote Link to comment Share on other sites More sharing options...
