Need to get it read at a dealer to see what code it is otherwise there is a way to make it flash the light but it involves taking wires and grounding them in sequence.
Several times, I have disconnected the battery for some work, and the air bag light came on. And stayed on.
Lexls is a contributor who has a great procedure for fixing this condition. Check out the search portion of this site.
Just be sure that you don't have a real problem with the air bag.
thanks for your replys, just to be safe i will take it to the dealer to make sure its not a problem with the air bag, my inspection expires this month, is that light on a cause for failure, i'll check lexls.com for the procedure also thanks
update on the light issue i just cleared the code 41 malfunction stored in memory and the light is off, so do i still have to it serviced or not thanks
If the light went off, you should be just fine. There should be no problem with the Air Bag. I went through this same problem with a Honda Accord, too. Turned out it was the same computer glitch. Don't waste good money going to the dealer.
Best of luck.
