HatBe Posted May 31, 2007 Share Posted May 31, 2007 These are the issues that I have with 92 LS400. The car is in good shape, no leaks, still running smooth and strong, I love this car. I just want to share these with you guys. 42K miles: (1996) - Power steering pump problem, replaced - Review mirror getting dark, replaced - Door lock switch malfunction, replaced 100K miles: (2001) - AC climate control LCD display failed, my co-worker changed later at 145K miles 115K miles: (2002) - Tachometer needle light only haft way, replaced the whole dashboard display, $150 150K miles: (2006) - power steering pump leak, rebuild, $250 - replace high pressure hose, $220 - steering valve malfunction, replaced, bought at eBay for $80 152K miles: (2006) - AC compressor lock up, and then function again, recharged R12 and ran for 8 months, $85 before second leak 160K miles (2007) - Leak at rear main seal, repaired at the transmission shop, $450 - Leak at oil tube, changed the o-ring dipstick, parts cost $7 - 161K miles (2007) - AC leak again, convert to R134a and find leak, replaced 2 o-rings and a gasket at the compressor, $270$ Quote Link to comment Share on other sites More sharing options...
flanker271 Posted June 1, 2007 Share Posted June 1, 2007 Your first PS pump failed so early, at 42K...wow Quote Link to comment Share on other sites More sharing options...
wwest Posted June 1, 2007 Share Posted June 1, 2007 These are the issues that I have with 92 LS400. The car is in good shape, no leaks, still running smooth and strong, I love this car.I just want to share these with you guys. 42K miles: (1996) - Power steering pump problem, replaced - Review mirror getting dark, replaced - Door lock switch malfunction, replaced 100K miles: (2001) - AC climate control LCD display failed, my co-worker changed later at 145K miles 115K miles: (2002) - Tachometer needle light only haft way, replaced the whole dashboard display, $150 150K miles: (2006) - power steering pump leak, rebuild, $250 - replace high pressure hose, $220 - steering valve malfunction, replaced, bought at eBay for $80 152K miles: (2006) - AC compressor lock up, and then function again, recharged R12 and ran for 8 months, $85 before second leak 160K miles (2007) - Leak at rear main seal, repaired at the transmission shop, $450 - Leak at oil tube, changed the o-ring dipstick, parts cost $7 - 161K miles (2007) - AC leak again, convert to R134a and find leak, replaced 2 o-rings and a gasket at the compressor, $270$ How come I don't see an alternator in there...? Quote Link to comment Share on other sites More sharing options...
HatBe Posted June 1, 2007 Author Share Posted June 1, 2007 These are the issues that I have with 92 LS400. The car is in good shape, no leaks, still running smooth and strong, I love this car.I just want to share these with you guys. 42K miles: (1996) - Power steering pump problem, replaced - Review mirror getting dark, replaced - Door lock switch malfunction, replaced 100K miles: (2001) - AC climate control LCD display failed, my co-worker changed later at 145K miles 115K miles: (2002) - Tachometer needle light only haft way, replaced the whole dashboard display, $150 150K miles: (2006) - power steering pump leak, rebuild, $250 - replace high pressure hose, $220 - steering valve malfunction, replaced, bought at eBay for $80 152K miles: (2006) - AC compressor lock up, and then function again, recharged R12 and ran for 8 months, $85 before second leak 160K miles (2007) - Leak at rear main seal, repaired at the transmission shop, $450 - Leak at oil tube, changed the o-ring dipstick, parts cost $7 - 161K miles (2007) - AC leak again, convert to R134a and find leak, replaced 2 o-rings and a gasket at the compressor, $270$ How come I don't see an alternator in there...? The original alternator is still OK, but I forget to mention the hood support shocks FAILed at about 12OK miles, and I plan to purchase it from ebay for about $50/pair to replace Quote Link to comment Share on other sites More sharing options...
