HELP ME PLEASE SOMEBODY. MY KEY WILL NOT COME OUT OF THE IGNITION UNLESS I DISCONNECT THE BATTERY. WHATS GOING ON? I LOVE MY 94 BUT I'M BE
GINNING TO HAVE ALL THESE LITTLE PROBLEMS. :huh:
p.s. sorry i'm new to this site ,i'm in little rock arkansas
it sounds like the switch for the transmission to sense it is in park is not being activated
resulting in the locked up key
yep!thats what i would say too.just go to the dealer or a mechanic to get it checked out becuase disconnecting the battery every time you get out the car isnt good because you keep resetting your ecu and then it has to re learn everything all over again! :D
I had the same problem, but it just turned turn that you have to push the lever into park with a little force and hear a click. Simple mechanical issue. Try that real quick before going further...
