Shayan Posted May 24, 2007 Share Posted May 24, 2007 hey, My rear struts bottomed out and they cluck cluck very loud. and after replacing my struts it rides better, doesn't bounce but the sound is still there? what can this be? any advice is much appreciated. thanks guys. Quote Link to comment Share on other sites More sharing options...
godfather18 Posted May 24, 2007 Share Posted May 24, 2007 hey,My rear struts bottomed out and they cluck cluck very loud. and after replacing my struts it rides better, doesn't bounce but the sound is still there? what can this be? any advice is much appreciated. thanks guys. rear stablizer bushings, thats ur problem, replace them and the noise will go away Quote Link to comment Share on other sites More sharing options...
Shayan Posted May 24, 2007 Author Share Posted May 24, 2007 do i have to take the struts off again to get to this? thanks alot for ur help Quote Link to comment Share on other sites More sharing options...
Shayan Posted May 24, 2007 Author Share Posted May 24, 2007 hey, I've called everywhere for the bushing no one has it any pic or any website that would have it? the dealer me no afford lol Quote Link to comment Share on other sites More sharing options...
godfather18 Posted May 26, 2007 Share Posted May 26, 2007 Here you go make sure u buy two of them, its number 13 in the picture just add two to your cart and enjoy thumpless riding http://www.trademotion.com/partlocator/ind...amp;catalogid=1 Quote Link to comment Share on other sites More sharing options...
steviej Posted May 27, 2007 Share Posted May 27, 2007 also known as sway bar bushings. funny how these little buggers can create so much noise when they are just a little bit worn. I replace my ($10 each and 45 minutes of my time) and it made a world of difference. steviej Quote Link to comment Share on other sites More sharing options...
Shayan Posted May 27, 2007 Author Share Posted May 27, 2007 wow man, you just made my day. i've called everywhere local asking for the rear stabilizer bushing and no one had it but the dealer. and now with the new name of sway bar bushing its at every store. hehehehheh thanks alot man by the way, how do you replace it? Quote Link to comment Share on other sites More sharing options...
steviej Posted May 30, 2007 Share Posted May 30, 2007 jack up the rear end and safely support it. Take a good look, it will become self explanitory. There is a bracket around each bushing. Two or three bolts come out, the bracket moves out of the way, the bushing has a slice in it so that you can get it on and off the sway bar. Put the new one on with a little white lithium grease, replace the bracket and bolts and off you go.....noiseless. The sway bar is attached at both ends so don't worry about it falling on your face, it won't. It will move a little when you remove the brackets, but not to worry. steviej Quote Link to comment Share on other sites More sharing options...
Shayan Posted May 30, 2007 Author Share Posted May 30, 2007 hey steve, I jacked the car up, but no sign of the bishings. i looked for 10 mins. mmmmmmmm Quote Link to comment Share on other sites More sharing options...
Shayan Posted May 30, 2007 Author Share Posted May 30, 2007 oh yeah, i saw the bushings they are in perfect shape , as if they have been replaced before. I found this long loking screw that hasa little spring wrapped around it its located between the gas tank and where the spare sits in. Its close to the strut stuff. and at the top nothing is holding that screw, so its medal hitting metal making the click click noise. What do i do abotu that? Quote Link to comment Share on other sites More sharing options...
Shayan Posted June 12, 2007 Author Share Posted June 12, 2007 My cluck cluck is gone, and my bushigns were in perfect condition, and it drove me nuts, well i went to the dealer got me a new set of anti vibration clips for $30 and now im cluck clcuck free. Quote Link to comment Share on other sites More sharing options...
godfather18 Posted June 13, 2007 Share Posted June 13, 2007 pictures? Quote Link to comment Share on other sites More sharing options...
Shayan Posted June 13, 2007 Author Share Posted June 13, 2007 pictures of what? the anti vibration clips? Quote Link to comment Share on other sites More sharing options...
godfather18 Posted June 14, 2007 Share Posted June 14, 2007 under your car where those clips go Quote Link to comment Share on other sites More sharing options...
Shayan Posted June 14, 2007 Author Share Posted June 14, 2007 those clips hold your brake pads together. mine used to move around and hit the metal off of the caliper , making the loud cluck cluck noise. Quote Link to comment Share on other sites More sharing options...
BigDan Posted June 15, 2007 Share Posted June 15, 2007 jack up the rear end and safely support it. Take a good look, it will become self explanitory. There is a bracket around each bushing. Two or three bolts come out, the bracket moves out of the way, the bushing has a slice in it so that you can get it on and off the sway bar. Put the new one on with a little white lithium grease, replace the bracket and bolts and off you go.....noiseless.The sway bar is attached at both ends so don't worry about it falling on your face, it won't. It will move a little when you remove the brackets, but not to worry. steviej Great stuff Stevie, I need to replace these bushings in my RX 300. Do I need to jack it up to take load off or just be able to get underneath? Thanks,Dan Quote Link to comment Share on other sites More sharing options...
